Normal Topic Problem during node movement (Read 2338 times)
Anshul
Senior Member
Apr 18th, 2009 at 6:46am
I am passing through a very different situation.
When I select some nodes and move them using mouse, some of the nodes deviates from their expected position. The biggest problem is that it happens 15 times out of 100; rest all the times it works fine.  One more thing, if nodes are without links then it happens 40 times out of 100.
I am unable to debug this because of ambiguous behavior. Can anybody help me to solve this problem?
Many thanks in advance,
Anshul
Re: Problem during node movement
Reply #1 - Apr 18th, 2009 at 7:47am
Could you copy here your code for events related to moving nodes, such as NodeModified and SelectionMoved?
Anshul
Senior Member
Reply #2 - Apr 18th, 2009 at 8:48am
We don't have any code for the same.The operation is performed implicitly.
Reply #3 - Apr 20th, 2009 at 5:39am
Please save the diagram that has such nodes to a file and email it to support@mindfusion.eu.
