Normal Topic Copy a node error in V1.0.2 (Read 2024 times)
Hai
Mar 24th, 2009 at 3:05pm
Hi Stoyan
As you've suggested before I used the following code for Copy a node as a part of Copy/Paste.
With the new version I get the Error "Value does not fall within the expected range."….
if (_dnodeCur_Sel_Node is ShapeNode) {
ShapeNode node = _dnodeCur_Sel_Node as ShapeNode; _dnodeTmpNodeCopy = new ShapeNode(node); <- here I get the error
The stack trace is :
at MS.Internal.XcpImports.CheckHResult(UInt32 hr)
at MS.Internal.XcpImports.SetValue(INativeCoreTypeWrapper obj, DependencyProperty property, DependencyObject doh)
at System.Windows.DependencyObject.SetValue(DependencyProperty property, DependencyObject doh)
at System.Windows.Shapes.Shape.set_StrokeDashArray(DoubleCollection value)
at MindFusion.Diagramming.Silverlight.ShapeNode.UpdateVisuals()
at MindFusion.Diagramming.Silverlight.ShapeNode.set_Shape(Shape value)
at MindFusion.Diagramming.Silverlight.ShapeNode..ctor(ShapeNode prototype)
at Innovashare.UI.Views.WorkFlow.wfDesigner_View1.CopyAction()
at Innovashare.UI.Views.WorkFlow.wfDesigner_View1.LayoutRoot_KeyDown(Object sender, KeyEventArgs e)
at System.Windows.CoreInvokeHandler.InvokeEventHandler(Int32 typeIndex, Delegate handlerDelegate, Object sender, Object args)
at MS.Internal.JoltHelper.FireEvent(IntPtr unmanagedObj, IntPtr unmanagedObjArgs, Int32 argsTypeIndex, String eventName)
This have worked without problems before… Is it something in your changes ?
Hai
Re: Copy a node error in V1.0.2
Reply #1 - Mar 24th, 2009 at 4:17pm
Hi Hai,
This should work better -
https://mindfusion.eu/_temp/DiagramLite_copyfix.zip
