Very Hot Topic (More than 25 Replies) ContainerNodes (Read 14726 times)
castefani
ContainerNodes
Mar 26th, 2009 at 12:58pm
You have an estimate of when ContainerNodes implement?
I need this urgent appeal
Re: ContainerNodes
Reply #1 - Mar 26th, 2009 at 3:04pm
Which of your requests is most urgent now - groups as in Visio, multiple resize or ContainerNodes?
castefani
Re: ContainerNodes
Reply #2 - Mar 26th, 2009 at 3:28pm
Thanks for the question.
ContainerNodes is very urgent for me.
Re: ContainerNodes
Reply #3 - Mar 27th, 2009 at 3:18pm
This adds a bare-bones implementation of ContainerNodes:
https://mindfusion.eu/_beta/diaglite_containers.zip
Currently it only lets you associate child nodes with containers like this:
ContainerNode container = new ContainerNode(diagram);
diagram.Nodes.Add(container);
container.Bounds = new Rect(10, 10, 200, 100);
ShapeNode node1 = new ShapeNode(diagram);
diagram.Nodes.Add(node1);
node1.Bounds = new Rect(20, 20, 50, 30);
ShapeNode node2 = new ShapeNode(diagram);
diagram.Nodes.Add(node2);
node2.Bounds = new Rect(90, 40, 50, 30);
container.Add(node1);
container.Add(node2);
Now the user can select and move the container, and the child nodes will follow it.
We'll implement containers serialization next week, and will add some properties that will let you customize them.
castefani
Re: ContainerNodes
Reply #4 - Apr 4th, 2009 at 10:22pm
EXTREMELY URGENT !!!!!
Thanks, but unfortunately there are still bugs.
1 - I created a ContainerNode and put 2 DiagramNode in this, using the ContainerNode.Add
     When you create a desire DiagramLink between the two internal nodes, until I can, but the visual effect is very weird.
     Would be nice if the link starts a node within a ContainerNode the DigtamLink not tried to connect to ContainerNode.
2 --
ContainerNode node = new ContainerNode (diagram);
node.AddExpandButton () -> "Object reference not set to an instance of an object."
3 --
node.AnchorPattern = new AnchorPattern () -> "Object reference not set to an instance of an object."
4 - In a given situation, must not accept the container node DigramLinks (Incoming and Outgoing). how can I do that?
castefani
Re: ContainerNodes
Reply #5 - Apr 4th, 2009 at 10:33pm
Too
How to define a shape for the container node?
Re: ContainerNodes
Reply #6 - Apr 6th, 2009 at 10:53am
https://mindfusion.eu/_beta/diaglite_containersv2.zip
ContainerNode now inherits ShapeNode, and you can set its Shape, AnchorPattern, etc.
To stop links from being connected to some node, handle the LinkCreating and LinkModifying events and set Cancel = true when you detect that the target node should not allow connections to it.
I cannot understand your point 1.
Sachin
Re: ContainerNodes
Reply #7 - Apr 6th, 2009 at 12:52pm
HI
1.0.2.23517 there is no container Node
how to implement this one also pls send one example of containeR Node
Re: ContainerNodes
Reply #8 - Apr 6th, 2009 at 1:01pm
The archive above should contain V1.0.2.23027, and it has ContainerNodes.
Sachin
Re: ContainerNodes
Reply #9 - Apr 6th, 2009 at 1:05pm
send that one example of containe node
Re: ContainerNodes
Reply #10 - Apr 6th, 2009 at 1:13pm
castefani
Re: ContainerNodes
Reply #11 - Apr 6th, 2009 at 1:35pm
I can not download the file above
Re: ContainerNodes
Reply #12 - Apr 6th, 2009 at 1:55pm
Try with some download manager tool or with a different browser.
castefani
Re: ContainerNodes
Reply #13 - Apr 6th, 2009 at 2:11pm
I tried IE8, Firefox and FlashGet, but without success.
You can send in email?
castefani
Re: ContainerNodes
Reply #14 - Apr 6th, 2009 at 2:28pm
I created one and put ContainerNode within 2 ShapeNode (ShapeNode A and B ShapeNode)
- When I create a DiagramLink from A to B, are visible Anchors of the container and not the B
- After the DiagramLink established between A and B, can not select the most DiagramLink, but selects the ContainerNode
