Normal Topic Horizontal text alignment (Read 2644 times)
nezzy
Oct 12th, 2010 at 12:03pm
Hi.
I create a shapenode, and sets the HorizontalTextBlockAlignment to left. When I add text to the shapenode it looks ok. The text starts at the left side of the node. When I save it to xml with SaveToXml("myNewDiagram.xml"), no errors.
I then use the LoadFromXml("myNewDiagram.xml"), no errors. But now the text is aligned central. For my custom created node's it works fine, but for shapenode's it's not working.
Any ideas?
best regards
Anders
Re: Horizontal text alignment
Reply #1 - Oct 12th, 2010 at 2:51pm
It looks like a bug, the alignment properties are never saved at all. We'll try to fix that for the 1.8 release.
nezzy
Reply #2 - Oct 13th, 2010 at 6:25am
Ok.
Thanks.
Anders
Reply #3 - Oct 15th, 2010 at 7:28am
Hi Anders,
Actually you are supposed to set text alignment via the TextFormat property. The rest were added when we introduced templating support, only to allow mapping TextFormat to something easier to bind to from node templates. V1.8 will serialize them too anyway, but for now you can set TextFormat instead of the individual properties to have working serialization.
