Normal Topic Two issues with Container Nodes (Read 3913 times)
Mathias Z.
DiagramLite is cool!
Oct 8th, 2010 at 12:05am
Hello Stoyan,
I have implemented a network-like diagram with Shape Nodes, connected via Links, where I automatically render the layout using SpringLayout.
This works very well!
Now I added Container Nodes, trying to group several Shape Nodes within one Container Node. But this isn't working like I was hoping...
My first issue:
A user can drag a child node outside the Container Node, even though I defined
  KeepInsideParent = true
for each child node.
It seems that this setting only ensures that the children are moved simultaneously with the Container Node - even if they have been moved outside the borders of the Container Node. I want them to stay within the border of their Container Node. Would I have to implement a Mouse event for this?
My second issue:
When I run the SpringLayout, the children often get re-positioned outside their Container Node.
I changed the  IgnoreLayout   (for both the childred nodes and the Container Node or only one of them) back and forth, but it would only come up with other challenges: in this case neither the Containde Node nor the childred are moved (this is somewhat okay), but the other Shapes in the diagram collide/overlap the Container Node.
Can you provide guidance?
Thank you and best regards
Mathias
Mathias
Re: Two issues with Container Nodes
Reply #1 - Oct 8th, 2010 at 7:58am
Hi Mathias,
1. Use this method to arrange diagrams with containers; you can try different inner/outer layout combinations to see which work better for your case:
void ArrangeContainers()
	var innerLayout = new LayeredLayout();
	innerLayout.StraightenLongLinks = true;
	innerLayout.EnforceLinkFlow = true;
	innerLayout.NodeDistance /= 2;
	var outerLayout = new LayeredLayout();
	outerLayout.StraightenLongLinks = true;
	outerLayout.EnforceLinkFlow = true;
	outerLayout.NodeDistance /= 2;
	Arrange(diagram, outerLayout, innerLayout);
private DiagramItemCollection GetContainerItems(ContainerNode container)
	DiagramItemCollection items = new DiagramItemCollection();
	foreach (DiagramNode node in container.Children)
		items.Add(node);
		foreach (DiagramLink link in node.GetAllLinks())
			DiagramNode node2 = GetOtherEnd(link, node);
			if (node2.Container == container && !items.Contains(link))
				items.Add(link);
	return items;
private DiagramNode GetOtherEnd(DiagramLink link, DiagramNode node)
	if (node == link.Origin)
		return link.Destination;
	if (node == link.Destination)
		return link.Origin;
	return null;
private void Arrange(Diagram diagram, Layout outerLayout, Layout innerLayout)
	foreach (DiagramNode node in diagram.Nodes)
		ContainerNode container = node as ContainerNode;
		if (container == null)
			continue;
		innerLayout.Arrange(diagram, GetContainerItems(container));
		container.UpdateBounds();
	outerLayout.Arrange(diagram);
	diagram.ResizeToFitItems(5);
static class ContainerExtensions
	public static void UpdateBounds(this ContainerNode container)
		if (container.Children.Count == 0)
			return;
		var r = container.Children[0].Bounds;
			r.Union(node.Bounds);
		container.SetBounds(r, false);
2. It seems we haven't implemented that constraint yet in Silverlight, you can find an example that implements it by handling NodeModifying here:
http://mindfusion.eu/Forum/YaBB.pl?board=diaglite_disc;action=display;num=128090...
