Normal Topic Link Control Points Multiply When Changing Style (Read 2501 times)
dolfandon
Oct 5th, 2010 at 12:38pm
OK, I have a link that has 4 ControlPoints when it is created. I set these from a geometry object. I then change the style of this link to Bezier and magically the ControlPoints multiply to 10. Can I tell it not to do this or create the link as a Bezier to start with so I don't have to switch it? Thanks.
link.Style = processMapPreferences.StrightLines ? LinkStyle.Polyline : LinkStyle.Bezier;
Don Miller
Re: Link Control Points Multiply When Changing Sty
Reply #1 - Oct 5th, 2010 at 1:18pm
It happens because links preserve their number of segments when you change the style. You can set Diagram.LinkStyle to Bezier as default value for new links. Another option is to set link.SegmentCount = 1 after setting link.Style = Bezier.
dolfandon
Reply #2 - Oct 6th, 2010 at 5:12pm
Thanks again Stoyan. Changing the default of the diagram from preferences instead of trying to change the style of the link after it was created did the trick.
Don
