Normal Topic Add & remove icons for a diagram node (Read 3096 times)
Mathias Z.
DiagramLite is cool!
Sep 27th, 2010 at 9:03am
I am excited about the new SpringLayoutTraits.frozen functionality.
To indicate for a user if a node in the diagram is "frozen" or not, I want to show a "pin" or "unpin" icon on the individual node. Important: as the user can change if a node is frozen or not, the icon on the node must be changed (replaced) at runtime.
I am successful in setting the image element of the node at runtime, but I need a better way (because first of all the icon looks very blurred since I have to make it very small, secondly I plan to add further icons to a diagram node at runtime, indicating other properties).
I create the diagram nodes following the approach you demonstrated in Tutorial 3 (defining a ControlTemplate). I was successful in "drawing" the icon in XAML and add it to the ControlTemplate (as a subordinate canvas). But I didn't find a way how to hide/remove/replace this "icon" at runtime.
I am programming in C# (but have to admit that I am not a C# expert).
Can you help?
Thanks a lot in advance
Mathias
Mathias
Re: Add & remove icons for a diagram node
Reply #1 - Sep 27th, 2010 at 11:52am
Perhaps the easiest way to do that is to add both the pinned and unpinned drawings to the template, and bind either the Opacity or Visibility property for one of them to a custom bool 'Pinned' property of the node class. To bind double or enum to boolean, you will have to specify an IValueConverter in the binding expression. The Pinned property setter would also set LayoutTraits[Frozen] if it's a CLR property, or do that from the OnChanged callback if it's a dependency property.
Another possibility is to define a visual state group with two states - Pinned and Unpinned - and call VisualStateManager.GoToState from the property setter or change callback. Then you could set a different Path or Canvas as content of the pin-button container depending on the current state, by adding ObjectAnimationUsingKeyFrames to the VisualStateManager storyboard.
Yet another possibility is to get a reference to the Canvas from an OnApplyTemplate override, and dynamically change the canvas content when the Pinned property changes...
Mathias Z.
Reply #2 - Sep 27th, 2010 at 4:53pm
Hello Stoyan,
thanks for this very speedy answer. I will check out your suggestions and provide feedback. It may take a couple of days...
Cheers
Mathias
Mathias
Mathias Z.
Reply #3 - Oct 2nd, 2010 at 10:40pm
Hello Stoyan,
I followed your advice and implemented a dependency property. It took me a while to understand how to do it right, but now it works great and does exactly what I wanted it to do.
Thanks a lot Smiley
Mathias
