Normal Topic Bring nodes in view (Read 3049 times)
donalmeida
Yay...
Bring nodes in view
Jun 2nd, 2010 at 9:04pm
I have a Silverlight tree control that lists all the nodes. When the user selects the node I select the node in the diagram (in code) this works fine. However, our users want the node to be brought in view if the selected node is not in the view.
Our diagram   Height="2880” Width="5120" and Bounds="0, 0, 2000, 3000".
How do we bring the selected node in view (in code) so the user does not have to use the scrollbar and find the selected node?
Don Almeida.
Re: Bring nodes in view
Reply #1 - Jun 2nd, 2010 at 9:19pm
Try setting ScrollX = node.Bounds.X - scrollViewer.ActualWidth / 2, and corresponding values for Y and Height.
donalmeida
Yay...
Reply #2 - Jun 2nd, 2010 at 10:26pm
This works great Stoyan. thank you for the quick reply.
(only if you get a chance can you please let me know how to add some animation and bring it slowly into view.. this is not a requirement from the users.. but you have something handy it might look better.. )
appriciate all your help.
thaks Don Almeida.
Don Almeida.
Reply #3 - Jun 3rd, 2010 at 7:46am
Try using the following method.
void ScrollAnimated(double x, double y, double seconds)
	var timer = new DispatcherTimer();
	int ticks = (int)(40 * seconds);
	double dx = (x - diagram.ScrollX) / ticks;
	double dy = (y - diagram.ScrollY) / ticks;
	timer.Tick += (s, e) =>
		if (ticks-- == 0)
			diagram.ScrollX = x;
			diagram.ScrollY = y;
			timer.Stop();
		else
			diagram.ScrollX += dx;
			diagram.ScrollY += dy;
	timer.Interval = TimeSpan.FromSeconds(1.0 / 40);
	timer.Start();
e.g. call ScrollAnimated(newx, newy, 0.5);
donalmeida
Yay...
Reply #4 - Jun 3rd, 2010 at 2:33pm
Perfect.. this is amazing Stoyan.. you go beyond what your customer asks..
Thank you,
Don Almeida,
Don Almeida.
Mathias Z.
DiagramLite is cool!
Reply #5 - Oct 18th, 2010 at 4:46pm
Stoyo wrote on Jun 2nd, 2010 at 9:19pm:
Hello Stoyan,
I applied the algorithm you described. My intention was to have the node in the center of the diagram (embedded in the scroll viewer). I made two improvements, which I would like to share if anybody is interesed:
  • Add half the node's width (respectively height)
  • Take zoom level into consideration. I found out that the scroll viewer's actual height/width needs to be adjusted.
Taking this into consideration, my code looks like this:
ScrollX = node.Bounds.X + node.Bounds.Width/2 - scrollViewer.ActualWidth / (2.0 * diagramArea.ZoomFactor / 100.0)
Cheers
Mathias
Mathias
