Very Hot Topic (More than 25 Replies) ContainerNodes (Read 14728 times)
Re: ContainerNodes
Reply #15 - Apr 6th, 2009 at 4:20pm
I've emailed the dll to the msn address you have registered here.
Re: ContainerNodes
Reply #16 - Apr 7th, 2009 at 9:16am
This version adds the Diagram.HitTestPriority property. Set it to ZOrder, and you will be able to select links inside containers.
https://mindfusion.eu/_beta/diaglite_hittestpr.zip
We are not sure whether the link end should be aligned to the container borders while drawing. Let us know if you don't like it, and we'll add some property to disable that for containers.
castefani
Re: ContainerNodes
Reply #17 - Apr 7th, 2009 at 6:58pm
How to disable a container receiving node links (AllowIncoming and AllowOutgoing)?
I did this and not working:
AnchorPattern anchor = new AnchorPattern ();
Anchor.Points.Add (NewAnchorPoint (0, 0));
Anchor.Points.Add (NewAnchorPoint (0, 50));
Anchor.Points.Add (NewAnchorPoint (0, 100));
Anchor.Points.Add (NewAnchorPoint (100, 0));
Anchor.Points.Add (NewAnchorPoint (100, 50));
Anchor.Points.Add (NewAnchorPoint (100, 100));
Anchor.Points.Add (NewAnchorPoint (50, 0));
Anchor.Points.Add (NewAnchorPoint (50, 100));
Foreach (var point in anchor.Points)
Point.AllowIncoming = false;
Point.AllowOutgoing = false;
MyNode.AnchorPattern = anchor;
Re: ContainerNodes
Reply #18 - Apr 7th, 2009 at 7:21pm
Try handling LinkCreating / LinkModifying and:
if (e.Node is ContainerNode)
     e.Cancel = true;
castefani
Re: ContainerNodes
Reply #19 - Apr 7th, 2009 at 11:33pm
Does not work right. Sorry I speak, but are missing some small features in DigramLite that is complicating my work.
Must be possible to disable a Node Receive Incoming and Outgoing Links.
castefani
Re: ContainerNodes
Reply #20 - Apr 8th, 2009 at 9:28pm
ContainerNode have Add and Remove methods, but I how I know if a node is already in the container?
It would be nice to have a "Contains" method or a property
List <DiagramItem> Children
Re: ContainerNodes
Reply #21 - Apr 9th, 2009 at 11:35am
This version adds the ContainerNode.Children property and removes the Add and Remove methods:
https://mindfusion.eu/_beta/diaglite_containers2.zip
Now you can call container.Children.Add, container.Children.Contains, etc.
Additionally, DiagramNode has AllowIncomingLinks and AllowOutgoingLinks properties. Set them to false for your containers to disable connecting links to them.
castefani
Re: ContainerNodes
Reply #22 - Apr 9th, 2009 at 11:39am
tks
castefani
Re: ContainerNodes
Reply #23 - Apr 9th, 2009 at 11:53am
ContainerNode is a container, such as the Canvas?
Is there any property in class NodeCollection as the Parent to the canvas?
This is my problem:
1 - Adciono a ShapeNode the diagram;
2 - Adciono a ContainerNode;
3 - When you drag the shapeNode on ContainerNode, I call ContainerNode.Children
4 - Even changing ZIndex for both ContainerNode is on ShapeNode
Re: ContainerNodes
Reply #24 - Apr 9th, 2009 at 12:43pm
It's just a logical containment; the node's Parent is still the diagram's internal Canvas. We'll add some kind of ParentContainer property; meanwhile you could use ShapeNode.Tag or a hashtable to associate containers to their children.
castefani
Re: ContainerNodes
Reply #25 - Apr 9th, 2009 at 5:23pm
Try the following to your notice an error:
1 - Create a ShapeNode
2 - Create a ContainerNode
3 - Place the ShapeNode established on 1 within ContainerNode using Children.Add
4 - note that even changing the ZIndex the ContainerNode is on Shapenode
There would be a good ContainerNode be a real container?
Re: ContainerNodes
Reply #26 - Apr 13th, 2009 at 12:25pm
This fixes the problem with ZIndex:
https://mindfusion.eu/_beta/diaglite_zindex.zip
Now you could set Zndex = 0 for containers that are created after their children.
shesh
Re: ContainerNodes
Reply #27 - Apr 22nd, 2009 at 4:17pm
I am using the dll from https://mindfusion.eu/_beta/diaglite_containers2.zip .
With the code below, I have the container node and Shape node arranged side by side. The layout class should respect the containment.
Even without the layout class, I am able to drag a node outside of the container class. I assume there is a work around to prevent this, but the basic design should be the child must stay within the boundaries of the parent.
Any fix release for this ?
       private void EncSeqDiag_Loaded(object sender, RoutedEventArgs e)
           ContainerNode Parent1 = new ContainerNode(DiagramLite);
           DiagramLite.Nodes.Add(Parent1);
           Parent1.Bounds = new Rect(10, 10, 200, 100);
           ContainerNode Parent2 = new ContainerNode(DiagramLite);
           DiagramLite.Nodes.Add(Parent2);
           Parent2.Bounds = new Rect(10, 10, 200, 100);
           DiagramLite.ShapeBrush = new SolidColorBrush(Color.FromArgb(50, 0, 128, 192));
           for (int i = 0; i < 20; i++)
               ShapeNode node = new ShapeNode(DiagramLite);
               node.Shape = Shape.Shapes["Ellipse"];
               node.Pen = new Pen(new SolidColorBrush(Colors.Black));
               node.Text = "node " + i;
               DiagramLite.Nodes.Add(node);
               Parent1.Children.Add(node);
           for (int i = 21; i < 40; i++)
               Parent2.Children.Add(node);
           Perform_Layout();
       private void Perform_Layout()
           var layout = new MindFusion.Diagramming.Silverlight.Layout.SpringLayout();
           layout.Arrange(DiagramLite);
regards.
Re: ContainerNodes
Reply #28 - Apr 23rd, 2009 at 9:35am
We'll add support for containers to the layout classes in a few days. You could handle NodeModified or NodeModifying and set larger container.Bounds if it's a child of the container that's being modified.
castefani
Re: ContainerNodes
Reply #29 - Apr 23rd, 2009 at 2:53pm
When saving the Diagram with SaveToXml and then recharge it with LoadFromXml, ControlNode.Children is empty
