Normal Topic Item movement from keyboard. (Read 5224 times)
Shane
Mar 27th, 2009 at 5:16am
Hi All,
I need the selected nodes on my diagram to move by pressing the directional keys on the keyboard.
The movement should be in sync of the directional key pressed.
Can someone please tell me how to do that.
Shane.
Re: Item movement from keyboard.
Reply #1 - Mar 27th, 2009 at 7:27am
Hi Shane,
You can move the selected nodes using the method from this post:
http://mindfusion.eu/Forum/YaBB.pl?board=wpfdg_disc;action=display;num=122710007...
Shane
Reply #2 - Mar 27th, 2009 at 8:29am
Hi Stoyan,
Can you tell me how to map the key pressing event and the direction i.e up,down.left and right with this method.
Shane.
Reply #3 - Mar 27th, 2009 at 11:47am
You could map the arrow keys like this:
RoutedUICommand cmd = new RoutedUICommand();
cmd.Text = "move left";
cmd.InputGestures.Add(new KeyGesture(Keys.Left));
CommandBinding cb = new CommandBinding(cmd, (sender, args) => MoveLeft());
CommandManager.RegisterClassCommandBinding(typeof(Diagram), cb);
Where your MoveLeft method calls MoveSelection with a Point arguments set to diagram.Selection.Bounds.TopLeft offset a few points to the left.
Shane
Reply #4 - Mar 27th, 2009 at 1:27pm
I am still not able to make it work.
The code used by me is as follows :
In window constructor :
           cmd.InputGestures.Add(new KeyGesture(Key.Left));
MoveLeft method defination :
   private void MoveLeft()
           MoveSelection(new Point(diagram.Selection.Bounds.TopLeft.X+10,diagram.Selection.Bounds.TopLeft.Y) );
MoveSelection method :
private void MoveSelection(Point newPosition)
           Point oldPosition = diagram.Selection.Bounds.Location;
           InteractionState ist = new InteractionState(diagram.Selection, 8, MindFusion.Diagramming.Wpf.Action.Modify);
           ist.Start(oldPosition, diagram);
           ist.Update(newPosition, diagram);
           ist.Complete(newPosition, diagram);
Can you please tell me what is that iam missing.
Shane.
Shane
Reply #5 - Mar 29th, 2009 at 5:43am
          MoveSelection(new Point(diagram.Selection.Bounds.TopLeft.X+10,diagram.Selection.Bounds.Top Left.Y) );
Shane.
Reply #6 - Mar 30th, 2009 at 8:58am
Instead of
call
d.CommandBindings.Add(cb);
and make sure the move step is larger than GridSizeX.
Anshul
Senior Member
Reply #7 - Apr 3rd, 2009 at 8:27am
I have made a handler to handle key down event. On keydown i want to move the selected item.
now problem is that, i am unable to hit the keydown event.
can anybody please tell me what is missing ?
Anshul
Reply #8 - Apr 3rd, 2009 at 8:34am
