Normal Topic Cancel Events and Programmatically Trigger Event (Read 1538 times)
sydneyos
Mar 28th, 2009 at 12:03am
I need a way to cancel a change of focus event, but the LinkDeselected event doesn't seem to have a Cancel option.
Also, can I programmatically cause a click or double-click event?  If not, is there a way for me to programmatically put a link in InplaceEdit mode?
Re: Cancel Events and Programmatically Trigger Eve
Reply #1 - Mar 29th, 2009 at 9:50am
You could set e .Cancel = true from both LinkSelecting and NodeSelecting if the link you need to prevent being deselected is currently selected. Another option could be to select it again from the SelectionChanged event. Call Diagram.BeginEdit(link) to put the link in edit mode.
