Normal Topic Issue with Links length on selection movement (Read 2930 times)
Shane
Mar 29th, 2009 at 2:06pm
I have written event handler to create bubble zoomin and zoomout effect for the nodes on mouse enter and mouse leave for nodes in the diagram.
The issue is related to the links when multiple nodes (which are selected) are moved with mouse cursor on one of the nodes, the length of the links is changing.
I think that it is because on mouse enter we are modifying node length and thus the link connected too it is also changing its length.
Any suggestion how can i resolve the issue.
Shane.
« Last Edit: Mar 30th, 2009 at 12:12pm by Shane »
Re: Issue with Links length on selection movement
Reply #1 - Mar 30th, 2009 at 12:39pm
You could try setting the node's RenderTransform, instead of modifying its Bounds, or otherwise disconnect the links temporarily from the node while it is zoomed. The easiest solution might be to add a clone of the node over he original, without links connected to it, and zoom it instead of the original node.
Shane
Reply #2 - Mar 31st, 2009 at 6:01am
The suggestion from your last post about creating a clone of the node over the original, without links connected to it, and zoom it instead of the original node seems to fit my requirements.
Can you please elaborate on the suggestion how can implement your suggestion. A sample code will be great.
Shane.
Reply #3 - Mar 31st, 2009 at 2:17pm
void DiagramMouseMove(object sender, MouseEventArgs e)
	if (dummyNode != null)
		Rect bounds = parentNode.Bounds;
		if (!bounds.Contains(e.GetPosition(diagram)))
			diagram.Nodes.Remove(dummyNode);
			dummyNode = null;
			parentNode = null;
	else
		DiagramNode node = diagram.GetNodeAt(e.GetPosition(diagram));
		if (node != null && node is ShapeNode)
			parentNode = node as ShapeNode;
			dummyNode = (ShapeNode)parentNode.Clone(false);
			Rect newBounds = dummyNode.Bounds;
			newBounds.Inflate(20, 20);
			dummyNode.Bounds = newBounds;
			dummyNode.Text = "dummy";
			diagram.Nodes.Add(dummyNode);
Shane
Reply #4 - Apr 1st, 2009 at 10:07am
Thanks for the code but can you tell me what is dummyNode and parentNode here.
Thanks again,
Shane
Reply #5 - Apr 1st, 2009 at 12:01pm
They are ShapeNode fields of the form class.
