Normal Topic Select Mode (Read 1271 times)
sydneyos
Select Mode
Apr 1st, 2009 at 12:44am
Is there a way to put the diagram into "Select" mode such that, when a user clicks and drags, they are selecting objects rather than creating a new one?  If there is no toggle setting for this, can you post and or point me to a code sample that does this?
Thanks.
Re: Select Mode
Reply #1 - Apr 1st, 2009 at 8:25am
Set Diagram.Behavior = Modify.
