Normal Topic HELP!! - Links pass over nodes (Read 1439 times)
tzippy
Apr 2nd, 2009 at 4:31pm
I have a terrible problem when I have links between 2 nodes that are not parent-child.
The links pass over the other nodes as you can see in this image:
http://www.i-rox.net/img/untitled.bmp
Please solve the problem ASAP.
Re: HELP!! - Links pass over nodes
Reply #1 - Apr 2nd, 2009 at 5:07pm
TreeLayout is intended to be applied only on trees. If you apply it on an arbitrary graph, it only arranges the elements of the graph's spanning tree and ignores links that are not part of it. You could loop over the Links collection and call the Route method of such links, after running TreeLayout.Arrange().
