Hot Topic (More than 10 Replies) Grouping of items (Read 11897 times)
Re: Grouping of items
Reply #15 - Apr 14th, 2009 at 7:51am
Calling AttachTo does not move the child node inside the group node automatically; it just ensures that the nodes will retain their relative position when the group node is moved. If you need that, you should set the child's Bounds coordinates to be inside the parent's Bounds before calling AttachTo. If you apply some layout algorithm, you should run the layout using the KeepGroupLayout option.
Anshul
Senior Member
Reply #16 - Apr 15th, 2009 at 9:28am
Hi Stoyan,
I have a groupNode which is a collection of some ShapeNode,Now what I want is; OnDoubleClick on groupNode I want to display all the child nodes of this groupNode and this groupNode should be removed from the diagram.
I have tried something like this but its not working..
DiagramNode node = diagram.ActiveItem as DiagramNode;
           if (node != null)
               node.Detach();
Now plz tell me what I can do ?
I hope you helps Smiley
Anshul
Reply #17 - Apr 15th, 2009 at 10:59am
private void OnNodeDoubleClicked(object sender, NodeEventArgs e)
	if (e.Node.SubordinateGroup != null)
		foreach (DiagramNode child in e.Node.SubordinateGroup.AttachedNodes)
			child.Visible = true;
		e.Node.SubordinateGroup.AutoDeleteItems = false;
		diagram.Nodes.Remove(e.Node);
Anshul
Senior Member
Reply #18 - Apr 15th, 2009 at 12:42pm
nops,its not working...
The group node is deleted but I am not able to see the child nodes.
Reply #19 - Apr 15th, 2009 at 12:54pm
Add a Debug.WriteLine(child.Bounds.ToString()) to check if the children are inside the group node's Bounds. If you apply some layout without using the KeepGroupLayout option, the children might not be where you expect them.
Anshul
Senior Member
Reply #20 - Apr 20th, 2009 at 3:55pm
Hi Stoyan,
I have created a groupNode of some childNode and put it transparent.Now when I click on Group Button, I gets all the child node inside that groupNode but when I drag this groupNode,all chilNode gets invisible.
I want to see all child nodes everytime(includes while dragging) in that groupNode.
Anshul
Reply #21 - Apr 21st, 2009 at 9:28am
Could you save that group to an XML file and email it to support@mindfusion.eu?
