Normal Topic Add a Comment in Grid View (Read 3235 times)
Sachin
Apr 14th, 2009 at 5:18am
HI
I need to add a comment in gridView  like Excel
is it possible in Diagramlight
Re: Add a Comment in Grid View
Reply #1 - Apr 14th, 2009 at 11:05am
This looks like what the ToolTip property of items does. You will still have to provide the UI for entering the comments text.
Sachin
Reply #2 - Apr 14th, 2009 at 12:11pm
HI
I dont want to use Tool tip i want to adda comment in DIagramlight
if i right click and add a cooment then it should be insert in diagram light user go and click or hover it should come like tool tip , i have a problem is
DIagramlight doesnt support Context menu
if i am using html context menu lot of problems
already posted this issue please give the good solution
Reply #3 - Apr 14th, 2009 at 3:24pm
How do you imagine we could add support for context menus when Silverlight does not provide right-click events? The only way to do that we found is via html contextmenu event handlers, and we don't think it's a good idea for a custom control to access the html page just to expose this as a builtin right-click event. What we could do is add a tap-and-hold event (as in PocketPCs), and then you would display a context menu when the users hold the left mouse button depressed for some time over an item. Let me know if this will do.
Sachin
Reply #4 - Apr 14th, 2009 at 5:20pm
HI Stoyo
First of all thanks for ur interest ,
i implemented context menu  using some third party tool , actualy  now what i want is i need to add COmments in Diagramlight Like Excel user double click and change it like that ,.  can u help to implement this one
Thank you
sachin
Reply #5 - Apr 15th, 2009 at 8:21am
You could implement entering the comment by creating a temporary ShapeNode and calling Diagram.BeginEdit(tempNode). Handle the NodeTextEdited event by setting the text entered as a Tooltip for the clicked node, and then remove the temporary one from the diagram.
