Normal Topic Moving Small Nodes (Read 1654 times)
marksolo
Suffering suckertash.....
Moving Small Nodes
Apr 14th, 2009 at 9:10pm
Is anyone having problem moving small Shape Nodes?
By "small" I mean like 2.2x2.2. For some reason I can not move these nodes even when I zoom in really close, they just snap back to their starting position.  If I resize them to a bigger size, then I can move them around, but if I reduce the size again, they can't be moved.  Was this a design feature?  If so how I do workaround it?
I have tried every handle type by the results are all the same.
Re: Moving Small Nodes
Reply #1 - Apr 15th, 2009 at 7:58am
The control does not allow creating such small nodes interactively. Seems if you create them from code, the validation code for the node size is executed even if you move the nodes but not resize them, and it does not allow the operation. We'll add some property to let you specify the minimal node size, and this should work if you set it to a smaller value than 2.2 x 2.2.
marksolo
Reply #2 - Apr 15th, 2009 at 4:10pm
That would be great.  Thanks for the quick action Stoyan.
These code generated small nodes are quite important to the software I am working on.
I think I still have a few months left of my free 12 month upgrade, but I hope you can release a new update soon.
