Normal Topic Add Image to Shape Node. (Read 4156 times)
SandeepGowda
Apr 15th, 2009 at 4:23pm
  I am using Same functionality as Sample FlowCharter example. Can we add the Images on the top of Shape Nodes in selection pane.(in Scroll pane,holding number of shape nodes)
Regards
Sandeep.
Re: Add Image to Shape Node.
Reply #1 - Apr 15th, 2009 at 6:45pm
Do you need images over the shapes in the listbox control?
SandeepGowda
Reply #2 - Apr 16th, 2009 at 6:06am
Stoyo,
Your absolutely correct,the Nodes which we transfer on to main Diagram View. On Top of Nodes i need to add images aligned center.
regards
sandeep
Reply #3 - Apr 16th, 2009 at 8:05am
If you need this only for the nodes that are in the ShapeListBox, try this:
private void Form1_Load(object sender, EventArgs e)
	Image img = Image.FromFile(@"C:\img\harley%204.jpg");
	foreach (ShapeNode node in ((ListBox)shapeListBox).Items)
		node.Image = img;
You might as well set the Image of the Shapes defined in the shape library that's shown in the listbox.
SandeepGowda
Reply #4 - Apr 16th, 2009 at 9:48am
Stoyon,
i tried to set image as below. Can you please help me where i am doing mistake.
ShapeNode taskShapeNode = m_taskSelectionDiagram.getFactory()
.createShapeNode(1, 1, 25, 25);
taskShapeNode.setShape(m_arrayTaskShapeNodes[index].getShape());
BufferedImage image = m_taskSelectionDiagram.createImage();
//Trying to set Image from Local Directory.taskShapeNode.setImage(imageIcon.getImage());
//taskShapeNode.setImageAlign(ImageAlign.Center);
// add to the Diagram view.
m_taskSelectionDiagram.getNodes().add(taskShapeNode);
nodeRenderer.createBufferedImage(index,
m_arrayTaskShapeNodes[index].getText(), image);
taskShapeNode.setHandlesStyle(HandlesStyle.DashFrame);
regards
sandeep
Reply #5 - Apr 16th, 2009 at 10:09am
In Java you can load an image using the ImageIO.read() method, if that's your problem. Also, you should call ShapeNode.setImage() before calling createImage() and adding the result to the node renderer.
SandeepGowda
Reply #6 - Apr 16th, 2009 at 10:30am
Thanks Stoyo,
i Set image prior to Creating Image. its working fine.
