Normal Topic AnchorPoints and Links (Read 1202 times)
jmquinlan
Apr 16th, 2009 at 3:40pm
I'm getting some odd behaviour with anchor points, I've added some anchorpoints to the rows of TableNode.
When I first try to create a link it forces the link end points to connect to the AnchorPoints, this is exactly what I wanted and expected.
Then I clicked a link, and selected the end point and dragged it as though I was going to reassign it to a different anchor point, unfortunatly I missed the anchor point and landed in the middle of the node. The end point of the link is now not attached to any anchorpoint but is instead linked directly to the node it self.
I expected it to reassign the link end point either back to the anchorpoint I had just moved it from or to the closest anchor point. Is there a way to veto the operation of dropping a link on a node if it not dropped onto an anchorpoint?
regards
Re: AnchorPoints and Links
Reply #1 - Apr 16th, 2009 at 3:54pm
Set Diagram.SnapToAnchor = OnCreateOrModify.
