Normal Topic Diagram fialed to host C1 true grid grid (Read 1832 times)
Hamdy Ghanem
Apr 15th, 2009 at 5:52am
I have a diagram I put a node control with C1  true grid , It saved successfully
but when I try to load again
this line
diagView.LoadFromXml(xdoc)
gives me this error
Cannot load hosted control of type 'C1.Win.C1TrueDBGrid.C1TrueDBGrid'.
Re: Diagram fialed to host C1 true grid grid
Reply #1 - Apr 15th, 2009 at 8:14am
Are you using our Windows Forms control? The assembly that contains the grid control should be loaded in your application at the time when you try to open the file, or otherwise Flowchart.NET cannot find the class whose instance it should create. You could pre-load the assembly using the Assembly.Load method, or simply create an instance of a class defined in that assembly.
Hamdy Ghanem
Reply #2 - Apr 15th, 2009 at 8:24am
It works fine now, after your help
many thanks for you
