Normal Topic flex grid as a control hosted by controlnode (Read 1183 times)
Hamdy Ghanem
Apr 20th, 2009 at 1:14pm
dear Stoyo
My diagram has a control node
this node hosting a C1 flexgrid
when saving the diagram the data which are in the grid not saved
how we let i saved with the xml file
to met us when open to reload the data again
Re: flex grid as a control hosted by controlnode
Reply #1 - Apr 20th, 2009 at 6:33pm
You could set the node's Tag value so that it's different from null, and when SerializeTag is raised for the control node, save the grid data from the event handler.
