Normal Topic Multiple selection on NetDiagram (Read 4651 times)
Pierre
Apr 21st, 2009 at 7:44am
Althought I set my Diagram.Selection.AllowMultipleSelection property to False, when I try to select mutliple nodes I get an JS exception on "document.ElementById()".
Do you have any idea of the the reason of this exception ?
Thanks for your help.
Pierre.
Re: Multiple selection on NetDiagram
Reply #1 - Apr 21st, 2009 at 11:01am
What ClientSideMode are you using?
Pierre
Reply #2 - Apr 21st, 2009 at 11:48am
Hi Stoyan,
I'm using ImageMap ClientSideMode.
Pierre.
Reply #3 - Apr 21st, 2009 at 12:02pm
Hi Pierre,
Multiple selection cannot be disabled in ImageMap mode at this time. We'll implement that in the next few days. We don't know why that document.ElementById() error would happen though, is there any line number and .js file name shown with the message?
Reply #4 - Apr 22nd, 2009 at 2:59pm
This version lets you disable multiple selection in ImageMap mode:
https://mindfusion.eu/_beta/netdiag_301pre.zip
AllowMultipleSelection is not saved in the viewstate yet, so you will have to set it every time upon Page_Load.
Pierre
Reply #5 - Apr 24th, 2009 at 1:01pm
Hi Stoyan,
I did not try your update version but I've some details of the previous error:
I use tableNode. It seems to work with shapeNode !?
Here are the javascript line code appearing when the error occures :
document.getElementById('_mfusion_DiagramView1_ClickedItem').value = '0:-1:-1:-1';__doPostBack('DiagramView1','_mfusion_DiagramView1_ClickedItem');
Pierre.
Reply #6 - Apr 24th, 2009 at 3:10pm
Hi Pierre,
Okay, we'll check what happens with tables.
