Normal Topic Deleting container node that has child control (Read 1779 times)
Hamdy Ghanem
Apr 22nd, 2009 at 6:18am
When I delete a container , that container has child nodes
the container delete and the children as well
but when I am checking the xml file I found them ( children) still in the xml file
and also they loaded in the digram but invisible
Re: Deleting container node that has child control
Reply #1 - Apr 22nd, 2009 at 8:31am
You could unfold the container before deleting it to make the child nodes visible, or set container.SuboardinateGroup.AutoDeleteItems = true to delete them together with the container.
Hamdy Ghanem
Reply #2 - Apr 22nd, 2009 at 8:36am
Thanks Stoyan
