Normal Topic Issues with Node Zindex manipulation (Read 2725 times)
egreen
Apr 21st, 2009 at 4:48pm
I have a "special" node for which i am setting the Zindex to 0 (let's call it 0-node) such that it will appear behind all the "regular" nodes and links in the diagram. So far so good. There are 2 issues though:
1. The shadows of the "regular" nodes (i.e. with Zindex>0) disappear behind the 0-node.
2. If a link is completely within the boundaries of the 0-node, then the link cannot be selected, even when i cancel the NodeSelected event. It appears as if the 0-node may be capturing the mouse-click event before the link, even though this doesn't make since considering it has the lowest Zindex.
Any help would be appreciated.
Thanks!
Re: Issues with Node Zindex manipulation
Reply #1 - Apr 21st, 2009 at 6:06pm
Assuming you are using Flowchart.NET, set Diagram.ShadowsStyle = ZOrder, and Diagram.HitTestPriority = ZOrder.
egreen
Reply #2 - Apr 22nd, 2009 at 12:44pm
Thanks! Exactly what I needed.
