Normal Topic Zooming on Node while MouseEnter (Read 2570 times)
Bala
Apr 22nd, 2009 at 6:36am
I want Zooming on node while MouseEnter, I have used double animation by using this reference
http://mindfusion.eu/Forum/YaBB.pl?board=wpfdg_disc;action=display;num=123994983...
Its working, the only thing which I want additionally is "The node should be zoomed while mouse is on the node, while mouseLeave from node then only zoom-out should be done."
Bala
Re: Zooming on Node while MouseEnter
Reply #1 - Apr 22nd, 2009 at 9:27am
Remove the sb.AutoReverse = true line, and start the reverse animation from the mouse-leave handler.
Bala
Reply #2 - Apr 22nd, 2009 at 12:15pm
Hi Stoyan,
I have removed sb.AutoReverse = true line and written this code for mouse-leave handler.
node123 = e.Source as DiagramNode;
	     ScaleTransform scale = new ScaleTransform();
	     scale.CenterX = node123.Bounds.X - node123.Bounds.Width / 2;
	     scale.CenterY = node123.Bounds.Y - node123.Bounds.Height / 2;
	     originalTransform = node123.RenderTransform;
	     TransformGroup tg = new TransformGroup();
	     tg.Children.Add(originalTransform);
	     tg.Children.Add(scale);
	     node123.RenderTransform = tg;
	     var xa = new DoubleAnimation(2, 1, new Duration(new TimeSpan(0, 0, 0, 0, 500)));
	     var ya = new DoubleAnimation(2, 1, new Duration(new TimeSpan(0, 0, 0, 0, 500)));
	     if (diagram.FindName("mouseLeave") != null)
		   diagram.UnregisterName("mouseLeave");
	     diagram.RegisterName("mouseLeave", scale);
	     Storyboard.SetTargetName(xa, "mouseLeave");
	     Storyboard.SetTargetProperty(xa, new PropertyPath("ScaleX"));
	     Storyboard.SetTargetName(ya, "mouseLeave");
	     Storyboard.SetTargetProperty(ya, new PropertyPath("ScaleY"));
	     var sb = new Storyboard();
	     //sb.AutoReverse = true;
	     sb.Children.Add(xa);
	     sb.Children.Add(ya);
	     sb.Completed += new EventHandler(sb_Completed);
	     sb.Begin(diagram);
But its not working.Node is still zooming even on mouse leave.Where I need to make correction in this code to work it out ?
Bala
Reply #3 - Apr 22nd, 2009 at 1:06pm
Are you sure the MouseEnter animation has stopped? Try forcing it by calling Storyboard.Stop().
Anshul
Senior Member
Reply #4 - Apr 23rd, 2009 at 2:17pm
Yes, I have tried...But have some problem.
Could you plz send reverse code for mouseLeave?
