Normal Topic Export pdf (Read 2523 times)
binoo
Export pdf
Dec 20th, 2009 at 11:45pm
I try to export my diagram with the PdfExporter. The nodes are print, but not the links.
For the link, I use the event DrawLink to draw Image and text like this :
  e.Graphics.DrawImage(img, rect);
Did you see the same problem ?
Re: Export pdf
Reply #1 - Dec 21st, 2009 at 11:30am
What DiagramLink.CustomDraw style are you using? Is there nothing drawn at all for the links in PDF, or only the image is not shown?
binoo
Re: Export pdf
Reply #2 - Dec 21st, 2009 at 2:51pm
Thanks for your reply.
The CustomDraw value is CustomDraw.Additional.
I make a project to show you the problem that I have and I notice that the real problem is that images and texts aren't at the good position.
Without the next line, we can see the texts and images, but with a translation Undecided ...
this.diagram.ResizeToFitItems(5, true);
Nb: I send the project sample to your profil email adress.
Thanks.
Re: Export pdf
Reply #3 - Dec 28th, 2009 at 5:10pm
This version should export custom-drawn links as expected:
https://mindfusion.eu/_beta/wpfdiag23_pdfcustom.zip
We'll release it next week if we don't find any new problems because of this fix 8)
binoo
Re: Export pdf
Reply #4 - Jan 4th, 2010 at 9:35am
Thank you very much !
