Normal Topic Moving control points along with node (Read 2741 times)
egreen
Apr 22nd, 2009 at 12:50pm
Is there some diagram setting such that when I move a node, the control points of its links will move similarly, and not remain static?
(Excluding the control point that is directly connected to the node, which already moves along with the node, and excluding the control point that is connected to the other node, which should  remain anchored and unmoved).
Thanks.
Re: Moving control points along with node
Reply #1 - Apr 22nd, 2009 at 1:15pm
Try with DiagramLink.RetainForm = true.
egreen
Reply #2 - Apr 22nd, 2009 at 2:52pm
Actually, this maintains the link's shape, but what I'm trying to achieve is for the control points to move the same on the X and Y axis as the node does.
thanks.
Reply #3 - Apr 22nd, 2009 at 3:13pm
It this link connected to a node just at one of its ends?
egreen
Reply #4 - Apr 23rd, 2009 at 2:41pm
No, it's connected on both ends.
Reply #5 - Apr 23rd, 2009 at 3:34pm
There's no builtin support for such behavior. You can implement it by handling NodeModifying and offsetting the positions of all intermediate points in ControlPoints by the same amount the node moved since the last NodeModifying.
