Normal Topic Node Visibility Issue (Read 1649 times)
Paul Eden
Apr 22nd, 2009 at 5:32pm
Hi
We have a bunch of nodes set to be expandable but (through other requirement) when we set visibility to hidden / collapsed on the node and the contained UIElement, the expander buttons persist on the diagram canvas.  Is this a known issue or do  you need more specific code example?
Many thanks
Paul
Re: Node Visibility Issue
Reply #1 - Apr 23rd, 2009 at 9:17am
Try setting the node.Visible property, instead of Visibility.
Paul Eden
Reply #2 - Apr 24th, 2009 at 9:25am
That did the trick Smiley
Many thanks
Paul
