Normal Topic Deselecting links/node on MouseUp (Read 2039 times)
egreen
Apr 25th, 2009 at 11:06am
I wrote a code that would allow a user to select an area to zoom in to by pressing the shift-key and dragging the mouse over the area.
The zoom-in works fine, however I try to deselect all the links and nodes which are automatically selected by Flowchart due to the Selection rectangle haing been created, but my DeselectAllObjects() method doesn't seem to have any effect.
private void diagramView1_MouseUp(object sender, MouseEventArgs e)
if (_active_key == Keys.Shift)
diagramView1.ZoomToRect(this.diagram1.Selection.Bounds);
_active_key = Keys.A;
private void DeselectAllObjects()
foreach (DiagramNode node in this.diagram1.Nodes)
node.Selected = false;
foreach (DiagramLink link in this.diagram1.Links)
link.Selected = false;
Re: Deselecting links/node on MouseUp
Reply #1 - Apr 26th, 2009 at 9:44am
At what point is that DeselectAllObjects method invoked?
egreen
Reply #2 - Apr 26th, 2009 at 12:14pm
oops. must have erased that part from the code snippet.
i'm calling it right after ZoomToRect inside the MouseUp method.
Reply #3 - Apr 27th, 2009 at 8:33am
Perhaps MouseUp is raised before the items are selected, so clearing the selection from there does not work. You could handle the NodeSelecting and LinkSelecting validation events and set e.Cancel = true when your application is in zoom mode.
