Normal Topic Disable Double Click on Shape Node. (Read 1345 times)
SandeepGowda
Apr 28th, 2009 at 11:50am
hi,
Can you help me in Disabling the Double Click on Shape  Node.
regards
sandeep.
Re: Disable Double Click on Shape Node.
Reply #1 - Apr 28th, 2009 at 11:55am
Set AllowInplaceEdit = false if you need to disable entering inplace edit mode upon double-click. Or check what happens in your NodeDoubleClicked handler.
