Normal Topic Error in Shape Node (Read 2082 times)
muthuhamid
Error in Shape Node
Apr 28th, 2009 at 2:02pm
Hi
Am getting the following strange error whenever i try to change property of Diagram or diagramview object in design time.
Could pls help what will be the problem is ?
Code generation for property 'DefaultShape' failed. Error was: ''ShapeConverter' is unable to convert 'MindFusion.Diagramming.Shape' to 'System.ComponentModel.Design.Serialization.InstanceDescriptor'.'
Hamid
Re: Error in Shape Node
Reply #1 - Apr 29th, 2009 at 8:07am
If you have recently moved to a newer Flowchart.NET version, Visual Studio might be using a cached older version to create design-time objects and try to assign them to properties of the newer version currently loaded in the form designer. Try the solution from his thread:
http://mindfusion.eu/Forum/YaBB.pl?board=fcnet_brep;action=display;num=118756457...
muthuhamid
Reply #2 - Apr 29th, 2009 at 8:29am
Thanks Stoyan.
