Normal Topic Toggle selection (Read 1639 times)
marie
Toggle selection
Apr 29th, 2009 at 1:50pm
I want to be able to toggle selection when ctrl is down. When user ctrl-clicks on a node, it is added to the selection. If the node is already in the selection, it should be removed from it.
In order to do that, I thought I would create my own code that handles selection by handling diagram.Clicked & diagram.NodeClicked. However, since I have diagramView.Behavior = DrawLinks, the selection is already handled before NodeClicked is called.
How can I manually handle selection and still be able to draw links? Am I supposed to use Custom Behavior?
Marie
Re: Toggle selection
Reply #1 - Apr 29th, 2009 at 1:55pm
With what Behavior value doesn't Ctrl+Click toggle the selection? Ctrl+Click should toggle the selection, while Ctrl+drag selects all nodes that intersect with the selection rectangle.
marie
Reply #2 - Apr 29th, 2009 at 2:02pm
Yes, it does Smiley! I guess my own code was hidding that functionnality.
Thanks a lot!
Marie
