Normal Topic How can I Restrict to link once for one anchor? (Read 3825 times)
khstar
May 6th, 2009 at 6:46am
Hello~
As I wrote as title,..
How can I Restrict to link just once for one anchor?
For now, I can link several times for one anchor. However It will make errors for my application...
Where can I fix this problem?
Re: How can I Restrict to link once for one anchor
Reply #1 - May 6th, 2009 at 8:03am
The control does not provide built-in support for this. Try to handle the ValidateAnchorPoint event, and set e.Cancel = true if any of the links that are already connected to the node has its OriginAnchor / DestinationAnchor set to the one for which the event is raised.
khstar
Reply #2 - May 6th, 2009 at 8:52am
Thank you for a reply~
However,.. Could you Show me an Example code shortly?
I cannot find out the way.
Reply #3 - May 6th, 2009 at 10:02am
private void diagram_ValidateAnchorPoint(object sender, LinkValidationEventArgs e)
	if (CountLinks(e.Node, e.AnchorIndex, e.Link) > 0)
		e.Cancel = true;
private int CountLinks(DiagramNode node, int anchorIndex, DiagramLink skipThisLink)
	int c = 0;
	foreach (DiagramLink link in node.IncomingLinks)
		if (link == skipThisLink)
			continue;
		if (link.DestinationAnchor == anchorIndex)
			c++;
	foreach (DiagramLink link in node.OutgoingLinks)
			continue;
		if (link.OriginAnchor == anchorIndex)
			c++;
return c;
khstar
Reply #4 - May 6th, 2009 at 11:17pm
Thank you so much!!
