Normal Topic Saving(Creating) diagram as image. (Read 2085 times)
muthuhamid
May 7th, 2009 at 7:47am
Hi
Am drawing some diagram with different types of the nodes (shape node and control nodes). now i need to save the diagram
as image. am using the following code to save the diagram as image. It is saved but the control node is not saving as image
simply a blank box is showing in the place of control node.
Can you help me what will be missing to see the control node also.
FYI : am adding the the user control to the control node ie some Chart(Graph) control.
The code is :
dim diagramImage As Image = Me.doc.CreateImage()
Hamid
Re: Saving(Creating) diagram as image.
Reply #1 - May 7th, 2009 at 10:06am
Hosted controls are rendered in the exported image only if they are native .NET controls that paint themselves in the OnPaint method. If a control is a wrapper around a Win32 control, Flowchart.NET cannot make it render itself on the bitmap's Graphics. You must handle the PaintControl event to implement image export and printing for such controls.
muthuhamid
Reply #2 - May 8th, 2009 at 4:00pm
Thanks stoyan
Could you pls post the sample code of how to implement image export.
thanks
hamid
Reply #3 - May 9th, 2009 at 11:40am
The PaintControl help topic has some sample code:
http://www.mindfusion.eu/onlinehelp/flowchartnet/index.htm?E_MindFusion_Diagramm...
