Normal Topic Shapenodes Freeze after loading from files.. (Read 1200 times)
khstar
May 11th, 2009 at 2:51am
I met problem that Shapenodes Freeze after loading from files.
After Load, Every shapenodes show its anchor points and I cannot select shapenodes at all , although I can select and move links.
Selecting shapenode by dragging (with Behavior=Drawlink, allowunconnectedlink=false)and Moving Slightly, Now it acts normally.
Where can I fix this problem..?
Re: Shapenodes Freeze after loading from files..
Reply #1 - May 11th, 2009 at 8:18am
Please email to support@mindfusion.eu a file showing this and the code for your event handlers related to selection, if any.
