Normal Topic Questions about groups (Read 1754 times)
Oskar
I like YaBB 1G - SP1!
May 11th, 2009 at 11:26am
1. We use AttachProportional to attach nodes to a main item. But it’s still posible to select any attached node and move, change and delete them without it effecting the main item or any of the other nodes in the group. Is it posible to prevent this in any way?
2. Is it possible to bind the attached items z-index to the main item so that ZTop and ZLevelUp effects all items in the group?
3. Are there any changes made to the rotation of groups? FollowMasterRotation dosen’t seem to work any more.
Re: Questions about groups
Reply #1 - May 11th, 2009 at 11:55am
1. Set attachedNode.Locked = true.
2. It's not possible.
Reply #2 - May 11th, 2009 at 12:22pm
3. It worked just as previous versions in my test: the attached node is not rotated, but is resized accordingly to the rectangle that bounds the rotated master shape.
Oskar
Reply #3 - May 11th, 2009 at 1:35pm
3. Is it possible to get the attached nodes to rotate instead of resizing them?
