Normal Topic Uid not saving (Read 2020 times)
darrenwwwa
Uid not saving
May 12th, 2009 at 2:20pm
In my TableNodes I am assigning a GUID to the Uid field.
I save the diagram using SaveToString().
I looked at the created XML and the Uid is not included.
Am I missing something? I see that each node has a new ID (starting with 0), but that is the ONLY unique identifier I can find for each node.
Is there a fix for this? Or just a work-around?
Re: Uid not saving
Reply #1 - May 12th, 2009 at 2:56pm
Are you assigning them to the Tag property? In such case, handle the SerializeTag and DeserializeTag event.
Re: Uid not saving
Reply #2 - May 12th, 2009 at 2:58pm
- now I see there is Uid derived from UIElement. The control does not use it nor saves its value. Use the Tag property instead.
