Normal Topic Need Truncating of ShapeNode's Text (Read 1649 times)
Bala
May 14th, 2009 at 1:05pm
I have created a Shape Node and put some text for it say "Shape Node Trial-Node1".
My node width is small and this text is large compare to the node. So I want this text should be truncated with respect to the width of the node, so in this case text should be displayed like this "Shape No.." .The remaining text should be truncated and represented by "..".
Is there any property for this?
Bala
Re: Need Truncating of ShapeNode's Text
Reply #1 - May 14th, 2009 at 2:39pm
This should display ellipsis, but does not work yet with our styled text formatting algorithm, so you will see them only if EnableStyledText is set to false:
node.TextFormat.Trimming = StringTrimming.EllipsisCharacter;
Bala
Reply #2 - May 15th, 2009 at 4:14am
Thanks stoyan, its working Smiley
