Normal Topic Problem with DelKeyAction (Read 2303 times)
tzippy
May 14th, 2009 at 10:18am
DelKeyAction works well only if I click with the rightButton on the selected item.
Re: Problem with DelKeyAction
Reply #1 - May 14th, 2009 at 10:46am
The diagram might not have the keyboard focus before you click on it. You could call Diagram.Focus() from the form_loaded event to automatically focus it.
tzippy
Reply #2 - May 14th, 2009 at 12:55pm
The diagram hes the keyboard focus and although it happens.
Reply #3 - May 14th, 2009 at 1:57pm
If the diagram is inside a ScrollViewer, set <ScrollViewer Focusable="False" ... >. Otherwise it has the nasty habit of stealing the keyboard focus.
tzippy
Reply #4 - May 17th, 2009 at 2:37pm
it helps.
