Normal Topic Problem with NodeDoubleClick (Read 1206 times)
Bala
May 18th, 2009 at 8:39am
Hi Stoyan,
I have to perform DoubleClick on the node.When I do the same (In Debugging Mode) control is shifted to NodeModified event,then it moves to DoubleClick event.Is their any way, by which only double click of node get calll?
Bala
Re: Problem with NodeDoubleClick
Reply #1 - May 18th, 2009 at 2:18pm
Hi Bala,
This should happen only if you click over a selection handle and move the mouse a few pixel between the two clicks. It might also happen if you have some breakpoint in mouse-down related events; the control could detect some mouse movement when you continue execution.
