Normal Topic Select object by code vb.net (Read 2420 times)
dzapata2007
May 19th, 2009 at 8:46pm
Excuse me, i'm new in using this software.
How can I make vb.net code to search a node, and once found to change image and text through code? could give an example
Re: Select object by code vb.net
Reply #1 - May 20th, 2009 at 5:28am
If you assign some Tag values to nodes, you could use the FindNode method to find a node:
Dim n As ShapeNode
n = Diagram1.FindNode(1)
If n IsNot Nothing Then
	n.Image = Image.FromFile("image.png")
	n.Text = "new label"
End If
If you need to search for nodes by some other criteria, do a for-each loop over diagram.Nodes and check if the node meets the condition.
dzapata2007
Reply #2 - May 20th, 2009 at 3:18pm
Dear Stoy,
When you run the example I gave (with the considerations of the case in relation to the Tag of the nodes) the problem I have is that Visual Basic 2008, you sent me the following error:
"Unable to cast object of type 'MindFusion.Diagramming.WinForms.Samples.VB.IconNodes.IconNode' to type 'MindFusion.Diagramming.ShapeNode."
FindNode () returns an object IconNode rather ShapeNode, with which I do not have access to the properties of the found object.
Thanks for your great and fast support.
Reply #3 - May 20th, 2009 at 3:39pm
If you are going to use only IconNodes, just define Dim n As IconNode. Otherwise use the TypeOf .. Is operator to check the type of the returned node, and then CType it to the correct type to use the appropriate properties.
dzapata2007
Reply #4 - May 20th, 2009 at 3:44pm
Dear Stoyo,
We apologize for the inconvenience, was the simple fix, just change the line defining the variable "n":
Dim n as IconNode
And everything worked properly.
Thanks for your support.
