Normal Topic Tablenode - Column visibility (Read 1967 times)
BidMaestro
to learn is to live
May 20th, 2009 at 10:38am
Do you have a means to make a Tablenode column invisible i.e. equivalent of visible=false.
The reason is that I have two columns of visible data and I would like to store a guid value in the third column which need not be displayed. I could make the column width=0 however the last instruction I perform is a ResizeToFitText(False, False) to resize the table and contents which would either show the guid data or if I set the width after the resize I would have a large blank column displayed in the table.
Hopefully this makes sense to you.
I have a second question; how can I determine the height and width of the tablenode? The reason is that I want to restrict it size to only display 10 rows where 30 or 50 rows may be in the table.
Doug
Re: Tablenode - Column visibility
Reply #1 - May 20th, 2009 at 12:55pm
Hi Doug,
You could store the GUID value in the Cell.Tag rather than Text. If all rows have the same height, multiply it by 10 and add CaptionHeight + 3 pixels to get the height that should fit 10 rows.
BidMaestro
to learn is to live
Reply #2 - May 20th, 2009 at 1:11pm
Thank you on the use of the cell.tag.
I understand what you are saying about the height calculation however the Tablenode does not have a height and width property to read or alter. The only time height and width are mentioned is when you create it; unless I have misread the Dev Guide.
On a separate matter with regard to Tablenodes other than changing the cell colour after it is clicked is there a way to select/highlight a row.
Doug
Reply #3 - May 20th, 2009 at 1:31pm
Changing the height can be done like this:
RectangleF r = table.Bounds;
r.Height = newHeight;
table.Bounds = r;
There is no built-in row selection, so you'll have to change the cell color or use custom drawing.
BidMaestro
to learn is to live
Reply #4 - May 20th, 2009 at 1:39pm
As always I appreciate your great help and assistance.
Almost midnight here and time for bed.
Have a good week.
I will put an entry in the Feature Suggestions for a Row Highlight function and Height & Width properties for the tablenode.
Doug
