Normal Topic Problem with cloneNode (Read 1209 times)
Bala
May 23rd, 2009 at 9:15am
I have a ShapeNode for which I have created a clone(say cloneNode). code for this is
ShapeNode cloudNode = sourceNode.Clone(true) as ShapeNode;
I have some child nodes(attached nodes) in sourceNode but in cloneNode those childNodes are not visible.
Is their any more property to set by which I can see the childNodes as well as part of clone?
Bala
Re: Problem with cloneNode
Reply #1 - May 25th, 2009 at 4:57am
There isn't such property. You could temporarily select this node and call CopySelection(..., true) and PasteSelection to clone the attached items too, and restore the selection after that.
