Normal Topic Clearing the Diagram Area (Read 1153 times)
BidMaestro
to learn is to live
May 31st, 2009 at 1:44pm
I use the diagram.clearall to clear all the nodes and links in my test program I have now loaded lanes, lanegrids and headers.
The diagram.clearall does not remove these new  items; is there a simple method for clearing the lanes, lanegrids and headers or can this be included in the diagram.clearall?
This would be usefull for resetting the diagram area back to a blank canvas.
Doug
Re: Clearing the Diagram Area
Reply #1 - Jun 1st, 2009 at 6:51am
Hi Doug,
Setting the LaneGrid's RowCount and ColumnCount to 0 should be the quickest way to reset it to blank state, and then you could add your default headers and lanes if needed.
BidMaestro
to learn is to live
Reply #2 - Jun 1st, 2009 at 10:37am
Thanks for that; it worked.
However I found another anomaly in my testing. When I create lanegrids and row/column headers it does not set the diagram.dirty=true flag.
In my test program I use thsi flag to determine if anything had been written to the diagram and prompt the user on whether they want to save or clear the diagram.
If you only created lanegrids with row/column headers with no other nodes then the flag would not be set to true and my test fails to clear the diagram
Hopefully this makes sense to you
Doug
