Hot Topic (More than 10 Replies) Adding a new node to ControlPoints collection (Read 3160 times)
corcav
Jun 3rd, 2009 at 10:08am
I have a diagram that has LinkStyle=Cascading and LinkSegments=3. I want to add a new controlpoint in a middle of an existing link segment programmatically, so i do:
link.ControlPoints.Insert(new PointF(x,y));
link.UpdateFromPoints(true);
link.UpdateIntersections();
What i get is that point is added but i miss last segment visually (link exists, but it appears unconnected).
If i click link handles i get weird behavior.
Did i miss something?
Re: Adding a new node to ControlPoints collection
Reply #1 - Jun 3rd, 2009 at 10:18am
Call the UpdateFromPoints(bool updateGroups, bool updateSegmentCount) overloaded method, with updateSegmentCount set to true. When modifying the points of cascading links, you must ensure that each segment is orthogonal to each neighbors.
corcav
Reply #2 - Jun 3rd, 2009 at 10:28am
Hi Stoyo,
I don't have such overload (using v5.1.1.23993) do i need to upgrade or do you have a (temporary) workaround?
Reply #3 - Jun 3rd, 2009 at 11:00am
corcav
Reply #4 - Jun 3rd, 2009 at 11:22am
Hi Stoyo,
Tried this but problem is the same...
    public void AddLinkSegment(DiagramLink link, PointF splitPoint)
     PointCollection savedPoints = link.ControlPoints.Clone();
     link.SegmentCount++;
     //Find segment
     for (int i = 1; i < savedPoints.Count; i++)
       PointF linkPoint = link.ControlPoints[i];
       bool isSameY = splitPoint.Y > linkPoint.Y - 2 && splitPoint.Y < linkPoint.Y + 2;
       bool isSameX = splitPoint.X > linkPoint.X - 2 && splitPoint.X < linkPoint.X + 2;
       if (isSameY && linkPoint.X > splitPoint.X)
         //Inject splitpoint
         savedPoints.Insert(i, new PointF(splitPoint.X, linkPoint.Y));
         break;
       if (isSameX && linkPoint.Y > splitPoint.Y)
         //Inject splitpoint
         savedPoints.Insert(i, new PointF(linkPoint.X, splitPoint.Y));
         break;
     for (int i = 0; i < savedPoints.Count; i++)
       if (i < link.ControlPoints.Count)
         link.ControlPoints[i] = savedPoints[i];
       else
         link.ControlPoints.Add(savedPoints[i]);
Method just adds a new point to provided link.
Reply #5 - Jun 3rd, 2009 at 11:39am
You should actually insert two points to preserve the othogonality of segments. Also you should remember the index where the points were added and change the second loop to
	if (i < insertIndex)
	else
		link.ControlPoints[i + 2] = savedPoints[i];
corcav
Reply #6 - Jun 3rd, 2009 at 12:01pm
Sorry but I'm getting lost... Undecided
You mean that i have to add the same point twice? (method adds just a single point) i did that (see code below) but i don't understand how to modify second loop.
     int insertionPoint=0;
     //Find segment
         //Inject splitpoint
         insertionPoint = i;
         break;
         //Inject splitpoint
         insertionPoint = i;
         break;
         if (i < insertionPoint)
         else
Thanks for your patience...
Reply #7 - Jun 3rd, 2009 at 1:02pm
Try this
	int insertionPoint = 0;
	//Find segment
			//Inject splitpoint
			insertionPoint = i;
			break;
			//Inject splitpoint
			insertionPoint = i;
			break;
	link.SegmentCount += 2;
There is a built-in feature that lets you insert news segments interactively; enable the AllowSplitLinks property and drag any point from a link segment to insert additional points there.
corcav
Reply #8 - Jun 3rd, 2009 at 2:35pm
Hi Stoyo,
Copied you code "as-is" but unfortunately it generates a "Index of of range exception" inside the loop:
That's because savedpoints.count=6 while link.ControlPoints.Count=4.
Looks like SegmentCount is ignored, code is exactly what you've posted before.
Reply #9 - Jun 3rd, 2009 at 2:37pm
If you are using AutoRoute, disable it before setting SegmentCount.
corcav
Reply #10 - Jun 3rd, 2009 at 2:47pm
Looks like your code works when Link.AutoRoute=false...  Smiley
