Normal Topic SaveToXml throw exception (Read 4280 times)
tzippy
Jun 4th, 2009 at 3:14pm
The method SaveToXml throw a stack overflow exception.
What could be the reason?
Re: SaveToXml throw exception
Reply #1 - Jun 4th, 2009 at 3:30pm
Are you using custom node types that override SaveToXml?
tzippy
Reply #2 - Jun 7th, 2009 at 7:15am
No, I'm using diagramNodeAdapter that get inside userControl.
I'm using custom link types.
Reply #3 - Jun 7th, 2009 at 8:26am
Do the custom links override SaveToXml? What is the method name shown at the end of the exception stack trace?
tzippy
Reply #4 - Jun 7th, 2009 at 9:50am
The ovverides in the project:
1. override InteractionState StartDraw(Point point)
for class that imports BehaviorBase.
2. override CursorHint SetMouseCursor(Point point, out bool startInteraction)
The exception doesn't reach the 'catch', so I don't have stack trace.
Reply #5 - Jun 8th, 2009 at 6:04am
Run the application through the debugger; it should stop when the exception happens and show a 'view details' popup. You can also see the stack trace in the debugger's Call Stack window (Debug -> Window -> Call Stack).
tzippy
Reply #6 - Jun 9th, 2009 at 11:36am
In the view details popup I see :
"Cannot evaluate expression because the current thread is in a stack overflow state."
The call stack ended with :
mscorlib.dll!string.CtorCharPtrStartLength(char* ptr, int startIndex, int length = 90) + 0x48 bytes
mscorlib.dll!System.IO.Path.NormalizePathFast(string path, bool fullCheck) + 0x1fd bytes
mscorlib.dll!System.IO.Path.NormalizePath(string path, bool fullCheck) + 0x25 bytes
mscorlib.dll!System.IO.Path.GetFullPathInternal(string path) + 0x16 bytes
Reply #7 - Jun 10th, 2009 at 5:12am
Could you email us a test project that reproduces this?
tzippy
Reply #8 - Jun 10th, 2009 at 7:05am
It's impossible.
The project is very large.
Could you focus us to the points that obstructive us?
Reply #9 - Jun 10th, 2009 at 7:21am
I didn't mean your whole application, but just a test project with your custom types added to it.
