Normal Topic Need Custom Position for Node's Text (Read 2436 times)
Bala
Jun 5th, 2009 at 6:43am
Hi Stoyan,
I have sent an image at your support mail-id, problem discription is also written their.Please have a look into that and give us the possible solution.
Bala
Re: Need Custom Position for Node's Text
Reply #1 - Jun 5th, 2009 at 9:28am
Hi Bala,
Quote:
Node's text should start from just beside the image (as in fig3) but if text is long enough, it should be truncated (as in fig 2).
You could use a TableNode with two cells, the first cell displaying the image and the second one displaying the text. If you prefer using ShapeNodes, try the following Shape definition.
var textOnTheRight = new Shape(
	Shapes.Rectangle.Outline,// reuse the rectangular shape
	null,// no decorations
	new ElementTemplate[]// define text region
		new LineTemplate(20, 0, 100, 0),
		new LineTemplate(100, 0, 100, 100),
		new LineTemplate(100, 100, 20, 100),
		new LineTemplate(20, 100, 20, 0)
	FillRule.EvenOdd,// doesn't matter here
	"TextOnTheRight"// to access the shape later using Shape.FromId
textOnTheRight.ImageRectangle = new Rect(0, 0, 20, 20);
Reply #2 - Jun 5th, 2009 at 9:35am
To align the text to the left:
StringFormat format = new StringFormat();
format.Alignment = StringAlignment.Near;
node.TextFormat = format;
Reply #3 - Jun 5th, 2009 at 9:40am
Quote:
I am getting a dirty border while selecting the node. I want a smooth border. How I can get this?
In the DrawAdjustmentHandles event handler, remove the hatchBrush and draw the selection rectangle using a solid-color pen.
Reply #4 - Jun 5th, 2009 at 10:16am
Quote:
I have attached a expand node inside this main node. But I get a dull + button on startup, Once you click on that button it gets clearly visible. Why it is so dull until I click on that.
Because WPF renders images blurred when they are not aligned to device pixels. The collapse/expand button has some code that aligns the image to the nearest device pixel when it is rendered, and it runs after click, so the +/- icon becomes more sharp. I suppose they appear blurred initially because of your scroll and zoom code at startup.
