Normal Topic Layout size constraint (Read 5171 times)
Pong
Jun 5th, 2009 at 11:17am
Is there a way to enforce a layout to arrange nodes inside a given size ?
Something like
MyLayoutObject.Arrange(size  SizeToArrangeIn)
Thanx in advance.
Re: Layout size constraint
Reply #1 - Jun 5th, 2009 at 11:37am
The force-directed layout classes have a LayoutArea property. For the other ones you might temporarily change Diagram.Bounds to set the position of the arranged graph, and use properties such as LevelDistance and NodeDistance to set the size.
