Normal Topic How to make node at the center of the diagram (Read 982 times)
ayushneema
Oct 14th, 2009 at 12:00pm
I am sending you a sample application.
My problem is that how can i set the nodes at the center of the diagram.
Ayush Neema
Re: How to make node at the center of the diagram
Reply #1 - Oct 16th, 2009 at 6:10am
From what I can see in the sample, the nodes are centered horizontally in the diagram area. And do you need to center them vertically too?
