Normal Topic How to shift/move content area on diagram. (Read 2014 times)
ayushneema
Oct 12th, 2009 at 9:18am
how can i shift my entire content area on diagram.
Ayush Neema
Re: How to shift/move content area on diagram.
Reply #1 - Oct 12th, 2009 at 10:17am
You could call GetContentBounds(), and from the result find a new value for Diagram.Bounds so that it has the content at the position you need it.
ayushneema
Reply #2 - Oct 12th, 2009 at 10:32am
Hi
Thanks for  replay..
I am using getcontentbound method. but how can i place the rectangle(from getcontentbound) to another location
could you please explain a bit more.
Ayush Neema
Reply #3 - Oct 14th, 2009 at 11:42am
Set diagram.Bounds = new Rect(newX, newY, oldWidth, oldHeight), where the newX and newY values depend on the content bounds, and the "old" variables contains the original width and height of diagram.Bounds. E.g. if you want the content to appear in the lower right of the diagram, set:
newX = contentBounds.Right - oldWidth;
newY = contentBounds.Bottom - oldHeight;
If you don't want to modify the origin of the diagram coordinate system (the top-left of Bounds), then you could loop over all nodes and add some offset to their coordinate, and over all links and add the same offset to their control points.
ayushneema
Reply #4 - Oct 15th, 2009 at 11:55am
Hi stoyan,
Thanks for clearing the doubts. i make the change and it working fine.
Ayush Neema
